who sells the full kit, cam, followers, spray bar, valve springs for the cheapest?
on burtons its £233+del
is there anywhere cheaper?
just buy the cam and standard followers, all the rest you can get from factor for half the price, even kents short pad followers are identical to standard ones and come from the same place with identical markings on.
With the money saved you get an adjustable vernier and get it set up propperly.
I think escort21 learned his lesson by buying a full kit, after 2 weeks a kent spring broke, and within another 2 weeks the follower wore out because the supplied kent spray bar oil jet completely missed the follower... now all that remains of the kit is the cam itself which i told him to just buy anyway.
fair do's, cheers
No probs :thumbsup: dont like to see anyone waste money...
and burtons is all i use..if youve used em before they may do free delivery and a plastic timing disc if you ask nice, they did for me.
Guest chriscapriman
Glyns right I learnt the hard way...kents cams are shite :mrgreen:
x2 :thumbsup:
i have bitten the bullit and shelled out for a Newman Ultimate Torque Cam
2000-6000 rev range and a nice long duration
have ordered it with the apropriate followers, double valve springs and caps
£344.90 all in
i will let you know the results :thumbsup:
Guest chriscapriman
fr30 is a great cam in a road capri or tina, lots of torque from low down, but fr32 is better in something lighter like an escort or track capri :twisted: . nowt wrong with profile specs of kent, but quality of all of thier components is poor in my experience :sad: , have heard very good things about newman, especially these carbide padded followers, think my next new kit will be one of these, depending on copeys :thumbsup:
yeah, i have heard good things too, i know its cost me £100 more than the kent would have, but after researching kent cams i decided to go for a newman cam as they are harderwearing
the cam i have aimed for is between the FR30 and the FR32
its a high torque cam but with a higher rev range, i spoke to Ken Newman and he agreed it would be the best cam for the spec of my engine and what i want to use the car for, he was very helpfull
spec:
2000-6000rpm .474" LIFT, 275/272deg DURATION, TIMING 110deg, .006"IN/.008"EX CLEARANCES
Don't forget a good oil will have a marked effect on cam life.
Valvoline R 20-50 will help cam life compared to something like GTX or the like.
If a cam has an agressive profile this is a good thing for performance, especially tractability, so be sure to use an oil with the sort of aditives required by these extreme presure profiles.
If after market cams improve an engine's performance you have to ask why ford didn't fit them - it's because of follower / lobe life.
Use good oil and follow the correct running in proceedures.
