nobby911 Posted November 9, 2009 Report Posted November 9, 2009 Hi I have just bought a 1600 sport which had the engine rebuilt 1000 miles ago and i have noticed that a little blue smoke comes out of the oil filler cap and also the filter on the oil catch tank. A couple of people have told me this is normal and not to woory about it and that its probably not fully bedded in yetbut then i read on the internet that the engine is knackered can anyone shed some more light on this. Also i was going to cheque the cylinder compression can someone tell me what it should be roughly. Haven't had or worked on an OSF for about 20 years so am learning as i go
over_head_cam Posted November 9, 2009 Report Posted November 9, 2009 Doesn't sound like it's 'knackered' but it sounds like it's breathing a bit. Is the engine modified? Has it been rebuilt by a reputable firm, or by the previous owner? Not sure about the compression except I know they should all be roughly the same Perhaps a post in the Crossflow and Pinto room or the W.P.E room may provide a more knowledgable answer
nobby911 Posted November 9, 2009 Author Report Posted November 9, 2009 hi, i only have the previous owners word on this but judging by the standard of the rest of the work I don't doubt some work has been done to the engine. It supposidly has been bored to a 1680cc with different cam and twin 40's
over_head_cam Posted November 9, 2009 Report Posted November 9, 2009 I'm not much of an engine expert, but there are afew on the site. I'm sure you'll get a more informed answer soon. Love the motor by the way
RossMK2 Posted November 9, 2009 Report Posted November 9, 2009 id say either breather or piston rings with the oil cap but probably breather
nobby911 Posted November 9, 2009 Author Report Posted November 9, 2009 cheers thanks for advice i have put a post in Crossflow and Pinto room. and fingers crossed i haven't bought a car with a knakered engine
over_head_cam Posted November 9, 2009 Report Posted November 9, 2009 I doubt a bit of smoke is too much to worry about. I've had smokey crossflows that go on forever
RossMK2 Posted November 9, 2009 Report Posted November 9, 2009 if it runs ok ignore it and check oil regurely
Miller Posted November 9, 2009 Report Posted November 9, 2009 My 1600 crossflow breathes heavy amd smokes a bit as well, in fact all of the crossflow escies I've had did. Ive never worried too much unless they started banging and rattling as well. They are pretty bullitproof motors even when theyve been played with so I wouldn't worry too much. On another note if its the car in your sig I nearly started selling body parts when it came on ebay, proper lush!
nobby911 Posted November 9, 2009 Author Report Posted November 9, 2009 Yes it is the one in my sig. Only got it last week. A mechanic friend said not to worry about it but then i started reading horror stories on the web.
Yeomans22 Posted November 9, 2009 Report Posted November 9, 2009 thats chris's car from stourbridge? had a look round it before when i bought some parts off him, he knows his stuff on osf's i wouldn't worry about it, the car he built is a cracker and he wouldn't have done a bad job on the engine either. Paul.
nobby911 Posted November 10, 2009 Author Report Posted November 10, 2009 Hi Paul, the car is ace, just not sure of the engine spec and seeing as its only done 1000 miles wanted to make sure i wasn't doing it any damage.
BIGKEV Posted November 10, 2009 Report Posted November 10, 2009 My engine Smokes and leaks but as peeps say you can run em forever
