d8vyr Posted December 31, 2009 Report Posted December 31, 2009 i`m looking for a bit more go for my 16 x/f but don`t want to go down the twin carb route so was looking for idea`s on a single carb set up.. what can you guys suggest cheers davy
over_head_cam Posted December 31, 2009 Report Posted December 31, 2009 Lynx made 'crossover' manifolds for single side-draught carbs
Fiesta Steve Posted December 31, 2009 Report Posted December 31, 2009 I like the old 32/36, as said above there are a few mods you can do to improve them
Copey Posted December 31, 2009 Report Posted December 31, 2009 I like the old 32/36, as said above there are a few mods you can do to improve them agreed, i have been reading up and a moded 32/36 is miles better than a 38DGAS few simple mods, bore out chambers and remove the 2nd choke, leave primary in for cold starts if youre on turbo sport there is a long detailed thread about it
5hane Posted December 31, 2009 Report Posted December 31, 2009 I like the old 32/36, as said above there are a few mods you can do to improve them agreed, i have been reading up and a moded 32/36 is miles better than a 38DGAS few simple mods, bore out chambers and remove the 2nd choke, leave primary in for cold starts if youre on turbo sport there is a long detailed thread about it Ill upload some pic's of one i started (on mates comp) I bored the bores from (iirc) 25 and 26 mm to 28/29 iirc, ive also filed / knife edged the venturi (think its venturi) and generally polished everything, still got to make a trumpet, and smooth th square bits did it about a year ago, and just havent got round to rebuilding / finishing it.. but ive got some before and after pic's the bores are HUGE compared to standard
