Guest cortinamad-gonetoo Posted February 22, 2010 Report Posted February 22, 2010 my battery light started coming on tonight when i brake or indicate or put wipers on etc ie under more load does this mean it the alternator at fault rather than a electric fault i hate electric problems
Yeomans22 Posted February 22, 2010 Report Posted February 22, 2010 i'd start by checking the connections on the battery alternator and anywhere else you can. if the problem is still there, then i guess battery or alternator problem.
bortaf Posted February 23, 2010 Report Posted February 23, 2010 Try wiggling the plug on the back, corosion can cause a resistance in the connection If you aint got a tester check all the earth conections, battery ect, failing that most battery places will test your alt for free in the hope of getting you to buy it from them, just drive off while he aint looking
mk1super Posted February 23, 2010 Report Posted February 23, 2010 had this woe too as said try get a test kit lidls are doing cheap ones seem to work ok and not even a 5 quid
Andrade Posted February 23, 2010 Report Posted February 23, 2010 does the bulb go off when you rev it a bit? I had similar problems on my viva during the engine change, but my problem was both alternator and battery so never really got to know which one it is
Guest cortinamad-gonetoo Posted February 23, 2010 Report Posted February 23, 2010 it goes off when not as much stuff turned on i tested for volts its 1383 with nothing on and engine idling then 1238 with lights on but i dont konw what results should be
Andrade Posted February 23, 2010 Report Posted February 23, 2010 it goes off when not as much stuff turned on i tested for volts its 1383 with nothing on and engine idling then 1238 with lights on but i dont konw what results should be Usually car batteries are 12V, my alternator delivers almost 14 (its from a KA). I recall my electrician saying amperage is important too, no idea about what the figures should be though
Retromotorsport Posted February 23, 2010 Report Posted February 23, 2010 grab the alternators pully.. and see if you can turn it, or put a spanner on the pully nut and see if you can turn it.. a slipping belt dosnt always squeal.. have a look at the bottom of the V ..it should be dirty, as the V belts ride on the sides , not the bottom, as they wear they hit the bottom and will always slip
Savvi Posted February 23, 2010 Report Posted February 23, 2010 It's not pushing out enough at those figures. Try testing it directly at the alternator also change the earth wire (from the volt meter) from the neg battery post to the alternator itself and see if the reading change. If you still get the same reading i'd say it's the alternator or if a bosh one fitted then you may be able to change just the regulator which is held on with 2 screws and has a black bubble on it as it sounds like the brushes are worn down
bortaf Posted February 23, 2010 Report Posted February 23, 2010 I'd say it was stuffed if it aint slipping, most decent batterys float (sitting idle after a few hours not used or charged) at about 12.7/8 volts and when running you should see 14 and it should be stable withing a few points of a volt when stuff is turned on like the dipped ect If you can get a sierra alt they are higher rated especialy if it's a Ghia model but check the alt connections as later ones have bolt on terminals and the pully changed depth in 87 (ish) and can cause all sorts of slipping problems if you mix and match em
Guest cortinamad-gonetoo Posted February 23, 2010 Report Posted February 23, 2010 found another alternater in my shed its a 35 amp one instead of 45 though i fitted it and tightened the fan belt correctly (its been checked for a second opinion) tightened the connections to alternater and rear lights and cleaned engine earth got readings of 1378 on tickover no lights etc on got 1338 at 3000 revs with as much turned on as possible also got a garage to do a free check with his meter and he didnt give me figures but said its charging ok both with and without load so i will see how it goes tonight
Guest cortinamad-gonetoo Posted February 23, 2010 Report Posted February 23, 2010 the round ones its still the same ?????????????
Andrade Posted February 24, 2010 Report Posted February 24, 2010 the round ones its still the same ????????????? Then its the battery probably. Whenever I used to drive at night and park somewhere I had to push my car to start. I actually used to find parking in a corner downhill (so no one parks in front of me). Get an Optima your starter motor will feel like its on steroids
Guest cortinamad-gonetoo Posted February 24, 2010 Report Posted February 24, 2010 but the battery was tested at a garage and he said its fine
Andrade Posted February 24, 2010 Report Posted February 24, 2010 but the battery was tested at a garage and he said its fine Did he test it with the lights on too? and how old is the battery? I mean, to troubleshoot the problem it would help if you can get hold of a battery from another car just to test it out on the running car. But a battery has X amounts of charge/discharge cycles, after so much use it might still be giving a reading but not doing its job to the full
Guest cortinamad-gonetoo Posted February 25, 2010 Report Posted February 25, 2010 tried another battery still does it yeah been tested both with and without lights on
