right it is that time of the year when the garage needs a fresh coat of paint (hasnt had one for years) but i am wondering if i need to prime it first? it is a Galvanised steel door, also what is the best type of paint to use that wont flake off in a matter of a few weeks like has happened before. :thumbsup:
Aldi had their metal paint in last week, used it before to good effect straight onto the door. Under £4 a tin, but only black, green, white, silver. meant to have rust inhibiting qualities. They might have some left.
rust inhibitor isnt a main worry for me as it has lasted years with no paint with it being galv, but it is a bugger to keep paint on it, is there anything i need to do, any sort of special primer or shall i just hammerite it?
Best thing to do with galv before painting is use an etching compound, used to use one called T wash, just brush it on, leave it to dry naturally and it sends the surface almost black as it dries, no further prep is needed, just let it dry out and away you go with the paint :thumbsup:
Here you go, this is the stuff...
http://cgi.ebay.co.uk/Mordant-Solution-T-Wash-5-Ltr-/320419751903?cmd=ViewItem&pt=UK_DIY_Material_Paint_Varnish_MJ&hash=item4a9a8167df
