BIG G Posted September 19, 2006 Report Posted September 19, 2006 Hello my friend its big g here we had luncheon at the ace rather plesant it was .Was the catch tank filter oily when you opened the bonet.If not you prob had a blockage in the tank pipework and this caused the oil to blow from the filler cap this blockage could be a fluid lock caused by the pipe work having a dip in it sort this by making sure the pipe work will let any oil flow back to the sump.The second prob could be a lump of shite in the line take off the pipe and blow back towards the engine this will shows thats not blocked next blow through tthe catch tank and see if theres a blockage there. You should run a pipe from the rocker to the catch tank this will solve this completely try and find a 1/2" bsp screwed hose tail and backing nut from a plumbers merchant prob get a chrome one to drill and fit to the rocker that easy i have a box of those fittings here at home but im in basingjoke best of luck. Thats just my advice/opinion take it or leave it
BaileyMex Posted September 19, 2006 Author Report Posted September 19, 2006 cheers guys, so at the weekend i'll check all of those points, and see if i can get the rocker breathing better too
BaileyMex Posted September 20, 2006 Author Report Posted September 20, 2006 Perhaps something like this tapped into the rocker cover and a small K&N breather on that???
