CrazyCharlie Posted July 19, 2010 Report Posted July 19, 2010 hi all i hope someone can help me im running a v6 cossie and i have a ally tank and swirl pot does anyone have a diagram or pics to pipe it up and do i need two fuel pumps its just theres 4 pipes in the swirl pot and i dont now how to do it cheers charlie
sambo Posted July 20, 2010 Report Posted July 20, 2010 Hi mate, plumb the fuel system like this: Take a facet, low pressure pump and use this to draw fuel from the outlet of your fuel tank to the third from the top inlet of the swirl pot. Use a low pressure filter between the tank and pump though. The fitting at the lowest point on the swirl pot is your main feed to the engine. From here, you'll use a pre-pump filter (injection H/P), into the injection pump. And after the pump use a post pump filter (injection H/P). This line will then go to your fuel rail and then into a high pressure regulator. From this regulator you'll need to go back to the swirl pot. Use the second from the top fitting for this. The fitting at the very top of the swirl pot is the over flow and this will need to be returned back to your fuel tank. I think thats everything mate. Good luck.
Andrade Posted July 20, 2010 Report Posted July 20, 2010 wait is that a v6 cosworth in a fiesta? crazy people
caprinerd Posted July 20, 2010 Report Posted July 20, 2010 wait is that a v6 cosworth in a fiesta? crazy people thats insane my kind of people on this forum
CrazyCharlie Posted July 21, 2010 Author Report Posted July 21, 2010 hi thanks very much thats a great help and yes that is a cos v6 in a mk1 fez
CrazyCharlie Posted October 3, 2010 Author Report Posted October 3, 2010 Hi mate, plumb the fuel system like this: Take a facet, low pressure pump and use this to draw fuel from the outlet of your fuel tank to the third from the top inlet of the swirl pot. Use a low pressure filter between the tank and pump though. The fitting at the lowest point on the swirl pot is your main feed to the engine. From here, you'll use a pre-pump filter (injection H/P), into the injection pump. And after the pump use a post pump filter (injection H/P). This line will then go to your fuel rail and then into a high pressure regulator. From this regulator you'll need to go back to the swirl pot. Use the second from the top fitting for this. The fitting at the very top of the swirl pot is the over flow and this will need to be returned back to your fuel tank. I think thats everything mate. Good luck. hi ive had it all running with two pumps a facet ticker pump from the tank and a high pressure cossy pump to the engine i took it to germany and the ticker pump packed up so im only running the high pressure one at the mo what would be the best low pressure pump to use from the tank cheers charlie
Fiesta Steve Posted October 3, 2010 Report Posted October 3, 2010 Vista posted this diagram the other day on another thread;
CrazyCharlie Posted October 5, 2010 Author Report Posted October 5, 2010 . all i realy want to no now is whats the best low pressure fuel pump .
JP. Posted October 5, 2010 Report Posted October 5, 2010 Well Facet pumps are most of the time very reliable. Have several Capri's running them for years now ( genuine red tops ) and never had issues with them. Once in a while i clean the fuel filter they carry inside them but as I run a throw away filter between the tank and pump also there's not much to find in the inside filter. I was warned for the cheap "so called" red tops from other brands.
Fiesta Steve Posted October 5, 2010 Report Posted October 5, 2010 . all i realy want to no now is whats the best low pressure fuel pump . Sorry Charlie, I read the original post ; does anyone have a diagram or pics to pipe it up and do i need two fuel pumps its just theres 4 pipes in the swirl pot and i dont now how to do it cheers charlie ..and thought I was being helpful. I didn't realise you resurected an old thread
CrazyCharlie Posted October 7, 2010 Author Report Posted October 7, 2010 . all i realy want to no now is whats the best low pressure fuel pump . Sorry Charlie, I read the original post ; does anyone have a diagram or pics to pipe it up and do i need two fuel pumps its just theres 4 pipes in the swirl pot and i dont now how to do it cheers charlie ..and thought I was being helpful. I didn't realise you resurected an old thread no props mate
CrazyCharlie Posted October 7, 2010 Author Report Posted October 7, 2010 is the red top facet pumps ok for the low pressure side i was useing the square ticker facet pump it did bout a 800 miles to the nurburgring then sucked the fuel line flat and packed up
CrazyCharlie Posted November 3, 2010 Author Report Posted November 3, 2010 does any one no what pressure fuel pump would be best from fuel tank to swirl pot a 4.0-4.5psi silver top facet a 6.5-7.25psi red top facet
Fiesta Steve Posted November 3, 2010 Report Posted November 3, 2010 does any one no what pressure fuel pump would be best from fuel tank to swirl pot a 4.0-4.5psi silver top facet a 6.5-7.25psi red top facet I think you are going to need volume rather than pressure but would rather go with the more powerful of the two to be sure
Andrade Posted November 3, 2010 Report Posted November 3, 2010 retro ford use the red top for swirl pots
sambo Posted November 4, 2010 Report Posted November 4, 2010 Anyone will be fine mate as they do chuck a lot of fuel through. Get a decent make and it will be reliable. Facet red-top is what i'm using.
CrazyCharlie Posted November 5, 2010 Author Report Posted November 5, 2010 cheers all i will be going with the red top i thinks cheers
