i ran a standard mechanical pump on my old 185 bhp Harris pinto with no problems . You just need a fuel pressure reg fitted between the pump and the carbs set at 2psi or else fuel will drip out of the trumpets on idle as the pressure will be too high :D
ive been running mechanical pump on a 2.1 with 45's for ages with no problems at all, ive got no pressure regulator. and have no fuel dripping from the trumpets at all :D:D
