retrorigg Posted April 26, 2011 Report Posted April 26, 2011 whats the score with fitting belts in the back of my mk2, its not far from been ready to play in but my young sons wanna come with me n would like to fit some belts in the back, is there a certain car they can be used from, are the mountings holes already in the car ????? cheers for any advice
RS2kSX Posted April 27, 2011 Report Posted April 27, 2011 I got a rear set from a late fiesta, you may have to cut an acces hole through your rear seat though... i managed to get the buckles in without cutting but it's very tight
Savvi Posted April 27, 2011 Report Posted April 27, 2011 I fitted brand new ones in mine last year. You can get securon from ebay or any other decent part shop, they come correct for the car with all the bits needed. You need the 264 ones seen here: http://www.securon.co.uk/applications/a ... s_ford.htm Instructions are included i did both sides in a couple of hours at home on the drive, they cost about £30 per side Worse part is drilling out the trim panel that runs down the side of the screen, but i found it was marked out on the inside once removed. Personally i would not use 2nd hand belts when i can buy new that cheap. There's some pic's on my thread "i couldn't resist"
Top Ghia Posted April 30, 2011 Report Posted April 30, 2011 I fitted brand new ones in mine last year. You can get securon from ebay or any other decent part shop, they come correct for the car with all the bits needed. You need the 264 ones seen here: http://www.securon.co.uk/applications/a ... s_ford.htm Instructions are included i did both sides in a couple of hours at home on the drive, they cost about £30 per side Worse part is drilling out the trim panel that runs down the side of the screen, but i found it was marked out on the inside once removed. Personally i would not use 2nd hand belts when i can buy new that cheap. There's some pic's on my thread "i couldn't resist" How did you get em at £30 per side the price list quotes £100 per belt unless iv'e got mixed up (quite possible)
Savvi Posted April 30, 2011 Report Posted April 30, 2011 I got mine from local motor factors, they had some in stock If you look on ebay they were about the same money when i did them last year. Here you go £24.95 plus £3.95 postage http://cgi.ebay.co.uk/NEW-Securon-Seat- ... 3a4cc7ef39
morcheen Posted April 30, 2011 Report Posted April 30, 2011 just sold these pair from a mk2 escort. made in 1998 so must have come off an existing car i think.
Top Ghia Posted May 1, 2011 Report Posted May 1, 2011 I got mine from local motor factors, they had some in stock If you look on ebay they were about the same money when i did them last year. Here you go £24.95 plus £3.95 postage http://cgi.ebay.co.uk/NEW-Securon-Seat- ... 3a4cc7ef39 Cheers mate ordered these from the bay.
