GJUK Posted November 1, 2012 Report Posted November 1, 2012 Hi, I've drained the coolant from my mk2 (which just had water in it). As its all probably coming to bits i do not want to re fit the pipework and fill it all with coolant. Will the engine be at risk of cracking due to the water expanding when it starts to freeze? I've drained the water from the bottom of the rad, though there must still be some water in the engine. Thanks. J
Admin Vista Posted November 1, 2012 Admin Report Posted November 1, 2012 Providing the coolant is drained as far as possible it should be fine as the space remaining will allow room for expansion if the water remnants freeze (though there shouldn't be more than dregs left in it). It's when the block is left full with no antifreeze that there's a real risk as there's no expansion room. If you've any doubts, drain the block as far as possible and then put a 1/2 litre of antifreeze in it to mix with the remnants of water left in there.
GJUK Posted November 1, 2012 Author Report Posted November 1, 2012 Providing the coolant is drained as far as possible it should be fine as the space remaining will allow room for expansion if the water remnants freeze (though there shouldn't be more than dregs left in it). It's when the block is left full with no antifreeze that there's a real risk as there's no expansion room. If you've any doubts, drain the block as far as possible and then put a 1/2 litre of antifreeze in it to mix with the remnants of water left in there. Thanks. I've drained it from the lowest point, the radiator drain. But i might chuck a little coolant in there to flush out the dregs /make a strong mix. Thanks
Admin Vista Posted November 1, 2012 Admin Report Posted November 1, 2012 Jack it up at the back to encourage as much of the remnants as possible to flow out
GJUK Posted November 1, 2012 Author Report Posted November 1, 2012 Jack it up at the back to encourage as much of the remnants as possible to flow out That sounds like a plan.
mk1estate Posted November 1, 2012 Report Posted November 1, 2012 why not just refill it with the correct anti freeze mix, its more than just a antifreeze and could help with any corrosion etc
