Hey Luke, started it in projects an restos mate :-)
Who's that? He got a consul? Just trying to work out sizes, might be a while before I get to putting one on or when I've saved up for one. Dunno wether to run English or atlas :-/
What engine, box and tyre size are you intending to use with your axle? 3.09 is a very tall ratio that gives long legs on a motorway run but is better suited to big capacity engines with lots of torque.
Hi rallysport04 long timeno see mate, what is it classic ford? How you mate?
Are the 3.09 Capri axles a fortune or quite available?
I'm after a long ratio vista, for motorway driving an ill have enough torque matey :-)
I run a 3.54 in my escort with type9 5speed an 175.50.13 tyres but that'll be way too revvy for what I'm after.
If I can't get hold of one ill have to run a 3.54 but unsure this will be low enough for me.
Is a mk1 Capri axle a English or atlas? Thanks guys :-)
Mk1 Capris had English and Atlas, think it was onls the V6s that had the Atlas? Mines a 1600 and its deffo a 50" English. Mk1 capri Atlas is pretty rare though and therefore expensive. Does plenty of torque mean V8? :D
Hi welshmike, what diff you running? Yeah they are a short atlas so well wanted for escorts :-/
No not v8, I'm keeping that part of my project under my hat ATM. :wink: everyone will see when it's done :-) lol
Tyre size absolutely does affect your speedo reading, it also affects your gearing. It's the 175/50's that are are causing your revs problem (i.e. too revy at high speed) get shot of them and it will disappear.
yeah i reolise that, should of worded it differently.. what i ment was at a particular rpm in a particular gear your speedo will read the same regardless of tyre size. just to clear it up :D
must have been classic ford its been a while ive been busy building a shed for my cars to live in the dry sick of working outside in the rain an flooded garden an rebuilding the rally car as i made a mess of it round snetterton in feb
mk1 3.0 cappa is a narrow atlas can be found on bay sometimes for not alot of coin just dont get fooled into it being a baby atlas baby atlas is 48" narrow atlas 50"
I could get away with one of them with the wheel offset I'm planning to use, an would be perfect but others will be thinking the same an that seems to boost prices, what are they worth complete?
You about this year? Yeah I got a garage now an love being indoors
What's the difference in koln axles? What diffs do they have, they are rear loading so are they ineterchangeable with anything else to achieve a ratio around 3.0-3.5?
How strong are they?
