from the pic it looks pretty rough, it will want opening up and checking at the very least. what do you mean by 'changing the end'
could you post more info and some more pics?
cheers, ian.
if your refering to the output shaft as the end then yes replacing it is a full strip down remove the lid have a look at the gears an selectors if there ok you can fit the prop on the box on an off a few times with w40 an it should clean the splines up if there not too far gone
sorry the pics not very clear,the end is round with no splines thats why i asked what its from.
its for my escort,i have opened it and the gears and selectors are all good.
just needed to know if i needed to have a complete rebuild to change the end to splined.
thanks for the replies
If really no spines then its wankered and you'll need a new output shaft and that's a full case strip! Probably why it was removed in first place!
just found out the bit on the end is actually whats left of the prop!
i pulled it and wiggled it and it came out!
i think the guy i got it from probably left it in while he stored it in his garage so it did not leak oil everywhere
