silverstreak Posted February 23, 2014 Report Posted February 23, 2014 got bad leak at front of gearbox where its attached to engine its leaking down both sides if u rev it u can c little oil bubbles coming out anyone got any ideas wot is causing this please
Admin Vista Posted February 23, 2014 Admin Report Posted February 23, 2014 Rear crank seal or sump gasket, though if it increases when you rev it's more likely to be the rear crank seal
silverstreak Posted February 23, 2014 Author Report Posted February 23, 2014 wot bout breather mite b blocked its still standard set up
rallyesport04 Posted February 23, 2014 Report Posted February 23, 2014 the filler caps the breather aswell as the pcv valve I would have thought if the pcv an filler was blocked it would blow the filler cap off
Admin Vista Posted February 23, 2014 Admin Report Posted February 23, 2014 the filler caps the breather aswell as the pcv valve I would have thought if the pcv an filler was blocked it would blow the filler cap off And the dip stick out
rallyesport04 Posted February 23, 2014 Report Posted February 23, 2014 ive had a x flow blow both out in the end I had to tie both down just to make it to classic ford an back one year
silverstreak Posted February 23, 2014 Author Report Posted February 23, 2014 hope its not rear seal or engine got to come out
Escort Mk1 4 Door Posted February 23, 2014 Report Posted February 23, 2014 my oil cap ejects if in up over 6k for more the a few seconds lol cant you drop the box instead to do the seal??
silverstreak Posted February 24, 2014 Author Report Posted February 24, 2014 think its headgasket colin from ashton mobile is going to check it 4 me
monkeymoreton Posted March 1, 2014 Report Posted March 1, 2014 Should of bolted that head down right the first time lmao
