dalmarshall Posted April 5, 2014 Report Posted April 5, 2014 I want to replace my fuel pipe for the more modern ethanol resistant stuff. Does anybody know the diameter I need. The cars not nearby for me to take a look, Mk1 mexico, cheers
joe1600 Posted April 5, 2014 Report Posted April 5, 2014 If its running a standard fuel pump it should be 6mm if a remember rightly
livewire7116 Posted April 6, 2014 Report Posted April 6, 2014 pop to B&Q to get some microbore copper pipe in the plumbing section, 8mm will also be fine
theloudboy Posted April 6, 2014 Report Posted April 6, 2014 No Darren don't buy copper pipe its eaten the steel pipes at work go to pirtek in Basildon they got it in a range of sizes
livewire7116 Posted April 7, 2014 Report Posted April 7, 2014 or buy the goodridge 600 hose at about £8 a metre and average £8 per fitting for the basic ones, do the job once and leave it!
James HPE Motorsport Posted April 8, 2014 Report Posted April 8, 2014 I would also recommend Torques UK for the aeroquip type fittings. Quality and price is very good. I believe the size you need for standard replacement pipe is 5/16 or 8mm!
deadly456 Posted April 25, 2014 Report Posted April 25, 2014 Well its 8mm on mine,got new all the way through
katana Posted April 25, 2014 Report Posted April 25, 2014 Not wishing to be controversial but ethanol is an alcohol and as most alcohols can be distilled in copper 'kettles' its effects on cooper pipe is somewhat bogus IMHO. Its effect on organic rubber and plastics can be explained chemically and so these are far more at risk.
