Lightweightsteve Posted August 7, 2014 Report Posted August 7, 2014 Due to a change of direction I have for sale my Mk1 Escort rear axle bits. They comprise : RS axle casing (with original anti tramp brackets) - the axle has the normal spring saddles, but also has mounts for coilovers and brake calipers if someone wanted to use them. I've bare-metalled it and painted it wih POR 15. Complete with half shafts, bearings and 3.89 diff in pigs head (only thing missing are the nuts that hold the pigs head on). It also comes with decent Cosworth front calipers and discs that fit, so is ready to bolt together. Furthermore, it comes with a set of 2wd Cosworth rear calipers with mechanical handbrake attachment which will need a refurb and slightly smaller discs. £250, collection from Devon Can strap to a pallet if you want to arrange a courier Cheers, Steve 07730 512532
Admin Vista Posted August 7, 2014 Admin Report Posted August 7, 2014 Cosworth front calipers on a mk1 Escort rear axle? That is surely overbraked?
Lightweightsteve Posted August 7, 2014 Author Report Posted August 7, 2014 I would have thought they definitely would have needed a bias valve, but it did come straight off a working rally car I'm told. Do look very meaty though!
