Hi,
The mechanical fuel pump on my 1300 crossflow has packed up so rather than replace it I'm thinking that I might as well update the system by fitting an electric fuel pump.
Please can you give me your opinions on what I should / shouldn't fit etc ?
Cheers
Darren
Depends on the spec of your engine. ie how much fuel you need and what pressure. A Facet silver top with an in line pressure regulator would be fine with a 1300. Wire it through a relay though.
Electric pump is a good move! I was running a 1700 Crossflow on twin 40's and it used to 'run out of steam' if it was getting booted! the mechanical pump can't keep up with a demanding engine.
