Changed oil pump yesterday Old 1 was running 40 then 20 on tick over then light came with no pressure, so change pump with 1 i had kicking around , Now i got mainly 75 but drops to 60 now & again. What does a high pressure pump run at ? Thought it was just a standard pump  :think: Any ideas cheers
You might not have a pump issue..
You might have an internal engine oiling issue like shot big-end bearings.
Oil pressure of 60 psi on a crossflow I would say is quite good. Depends on what spring has been fitted to relief valve determines oil pressure. The pump to have is high pressure high capacity. You can soon lift the pressure on a standard pump by fitting a washer between the pressed cup on face of pump and spring thus putting more pressure on relief spring hey presto more oil pressure
