seaneylad Posted June 8, 2015 Report Posted June 8, 2015 Hi guys anyone know the weight of this trying to work out quotes for transports.Thanks
seaneylad Posted June 8, 2015 Author Report Posted June 8, 2015 Back cab is fibre glass so wont weight much
Ray Posted June 8, 2015 Report Posted June 8, 2015 the size of transporter you need, the weight probably wont come too much into it, it will be the dimensions, it was certainly the case when i had to have a 3.5 ton long wheel base flat bed transit recovered, as the size of the recovery truck needed took that sort of wagon with ease
Ray Posted June 8, 2015 Report Posted June 8, 2015 that said it wasnt cheap either, 10 mile trip was £110
seaneylad Posted June 8, 2015 Author Report Posted June 8, 2015 that said it wasnt cheap either, 10 mile trip was £110 Cheers had some quotes around £125-150 for 40 mile Journey. Need to get to some measurements to double check
colr6 Posted June 8, 2015 Report Posted June 8, 2015 Hi, going back my MOTing days 20yrs ago 1550 to 1700kg hope this helps Colin
seaneylad Posted June 8, 2015 Author Report Posted June 8, 2015 Hi, going back my MOTing days 20yrs ago 1550 to 1700kg hope this helps Colin Cheers
