atlas axle, non LSD fromn a capri.
im in the process of fitting an LSD unit to my 3.77 atlas, got 3 out of 4 driveshafts out fine buy using the reversed drum method but the last one (in the axle casing i need) is stuck solid.
any ideas for me to try?
cheers in advance.
Try a reversed steel wheel and a bigger hammer bud... If that dont work you'll need a puller/slide hammer :shock:
