Hi guys first of all let me say that since joining this club i have managed to participate in the Midlands to Wales run 2015 and the Classic Ford Show which i enjoyed both immensely and that is mainly down to you guys! all the people that i have met and those that have given both  words of wisdom and opinions.  for that i thank you all  :bow:
Sadly and with a very heavy heart the time has come for me to let go of my old fords for a while at least !.
I have The mk2 Cortina 1600E "in the almost Alan Mann colours" which has the 2.0ltr Pinto EFI engine which was originally built by a guy called Luke and has featured in 2 or 3 ford magazines .
I also have my mk1 Escort 2 door which so far has had almost every panel replaced with new ones and is in the welders shop right now being almost complete.
Panels .....
2x front Mexico wings new.
2x inner wings new.
front panel new
complete floor pan new
rear seat brace new
2 x rear arches new
2 x sills new
1 X SLAM PANEL
all of these new panels are on and the shell is almost complete.
Obviously i have spent money on all new parts for when the old girl was ready to put back together the list is as follows.
ROOF GUTTER TRIM CHROME                                                           £34.98
EUROQUIP BLACKLINE S/STEEL BRAKE LINE HOSE KIT                 £44.25
AVO RS2000 HEAD LIGHT RELAY LOOM                                           £26.99
MK1 RS2000 FUEL LINE PIPE AND GROMMET                                 £68.98
ESCORT MK1 PANHARD ROD KIT                                                       £70.00
POWERFLEX LEAF SPRING SHACKLE MOUNTS                               £19.14
MK1 RS2000 ENGINE BAY HEADLIGHT W/LOOM                               £13.98
MK1 ESCORT 6 DIAL DASH STEEL BACK PLATE                               £36.99
REAR LEAF SPRING SADDLES GROUP 4                                            £12.95
ACCELERATOR PEDAL COVER MK1 RS2000                                     £14.10
FORD MK1 ESCORT SEAL KIT RUBBER doors + windows                £269.00
MK1 RS2000 QUICK STEERING RACK 2.4 KIT +TRACK ROD ENDS       £190.90
MK1 ESCORT RS2000 SINGLE PIECE PROP SHAFT                                £119.90
MK1 RS2000 FACTORY CORRECT PROPSHAFT BOLTS                         £15.49
MK1 ESCORT S/STEEL DOOR MIRRORS (PAIR)                                       £44.95
MK1 ESCORT ¼ BUMPERS WITH BOLTS                                                  £172.99
MK1 RS2000 PINTO COOLANT HOSES BLACK TWIN CARBS                 £126.90
MK1 ESCORT REAR AXLE BUMP STOPS IN POLY                                   £25.57
 MK1 ESCORT FULL GRILL CLIP SET RS2000                                           £13.93
MK1 ESCORT PEDAL RUBBERS, BRAKE + CLUTCH                               £11.50
REAR MK1 ESCORT BUMPER SPACERS RS2000                                    £6.39
MK1 RS2000 WIPER ARMS S/STEEL                                                          £36.14
MK1 RS2000 WIPER BLADES        £36.14
MK1 RS2000 FRONT COIL SPRINGS 170LB -2”                                         £50.00
MK1 RS2000 FRONT BUMPER SPACERS                                                  £14.10
TRACK CONTROL ARMS RH +LH MK1 ESCORT                                       £45.99
MK1 ESCORT 7” SEALED BEAM HALOGEN CONVERSION KIT              £99.99
MK1 RS2000 REAR LEAF SPRING SHACKLES                                           £26.94
MK1 ESCORT ROLL BAR ANTI DIVE KIT                                                     £49.94
MK1 RS2000 ANTI TRAMP KIT        £67.94
MK1 ESCORT DOOR SEALS X2, BOOT SEAL X1 RUBBER KIT                 £37.00
ACCUSPARK ADJUSTABLE REV LIMITER 4 CYL CARS                            £37.90
MK1 BOOT AND BONNET BOLT SET RS2000                                             £6.99
MK1 ESCORT S/STEEL DOOR HINGE PINS                                                £7.59
MK1 ESCORT DOOR CHECK STRAP PINS S/STEEL                                  £5.69.
Mk1 ESCORT REVERSE LIGHTS NOS LIGHTS                                                        £53.00
Escort AVO adjustable rear Mk1 shocks                                                         £155.00
MK1 ESCORT PEDAL BOX +CLUTCH ATTACHMENTS                     £36.00
MK1 ESCORT IGNITION WIRING LOOM                                        £26.00
MK1 ESCORT IGNITION BARREL AND KEY                                                £98.88
MK1 ESCORT -2 INCH LOWERING BLOCKS+ U BOLTS                           £27.42
        Total £2258.53
And that total is without all the panels welders fees and of course the car was sand blasted when i first purchased it.
I purchased the car as a running car so all of the other bits are there aswell . it would take someone to finish the little bit of fitting/welding and then put it back together again there is a full wiring loom that comes with the car and it cam off of a mk1 escort that was running a pinto engine.
I also have a pair of black almost perfect condition original mk1 escort seats to go with it , back seats and rear roll cage.
I will add some Pictures at the bottom of this post but please bare in mind that i am just waiting for the welder to send me some updated photos the ones of the Escort were taken  2nd May.
alternativly if you look on Retards Club at paint wizards hes profile pic is of an orange and white VW camper you can see the pictures he has posted, he is also a body work / painter too so if you wanted him to complete then im sure you could come to some kind of arrangement.
There is also a HARRIS 2.1 PINTO on running twin 45S that still obviously hasnt been fitted yet as is still in the same condition that i picked it up from Jeff and James. i supplied the 45s and the Harris`s did the rest. you can see the engine on this forum in the HPE thread
As i reluctantly sit here writing this post  i am still racking my brain as to find other ways of finding the money i need , but i cant, and yes im sure i will regret it once its all gone!!!!!!
Okay down to the nitty gritty everything must go as a one off deal, "how to put a price on it all?
£16000 BUYS THE LOT OVNO
I AM OPEN TO VERY SENSIBLE OFFERS AND EVERYTHING MUST GO TOGETHER
i SHOULD BE GETTING SOME MORE PICS SENT TO ME OVER THE NEXT COUPLE OF DAYS AS THE WINGS ARE NOW ON AND AS I SAID THESE WERE TAKEN MAY2ND, PLEASE FEEL FREE TO CHECK OUT THE Retards Club PAGE   "PAINT WIZARDS"
AS I AM AWAY AT THE MOMENT ITS BETTER WE CORRESPOND  ON HERE OR ON MY EMAIL  bazoffshore@hotmail.co.uk
ANY VIEWING CAN BE ARRANGED FOR INTERESTED PARTIES ONLY PLEASE,
ALL THE BEST GUYS .
Barry.
will end up on EBAY but thought i would  put it up here first , i am sure i have forgotten some new parts i have purchased but as you can see there is a lot.
I AM IN THE WEST MIDLANDS (TELFORD)
Lovely cars and always sad to see someone sell the pride and joy..
Don't know whether it's just me, but that yellow pricing is unreadable as it's too bright..might want to edit it to something less eyeball burning...
Hows that any better? in WHITE
:-) worse. Now those who use the white skin, the mobile skin (and possibly also those on Tapatalk) can't see it at all!
Hi as promised here are some more updated pics of my MK1 2 DOOR ESCORT  just sent to me by a friend.....
post-13566-0-81122500-1436540765_thumb.jpg       post-13566-0-87450400-1436540793.jpg
kind regards
Barry
  • 2 months later...
Guest
