None of it reaches again, could I just use the old 1100 distributor and coil on the 1600 for the time being and then sort the electronic one later? Or are they different
If the engine came with it, should be timed up (hopefully ) ready to go. Saves you having to do it. Surly the wire can't be that far away. The wire from dist to amp should be long enough. So should only be wire from amp to coil and red feed wire that's short?
Cheers for the help, I'm going to look at it again now maybe see if I can find anything wrong somewhere on it
I've just changed to my old coil which worked before I took it off but still got no spark
Why don't you get someone that knows what a switched live feed is to look at it for you .
Might be a bit less painful in the long run .
Good luck ,puddy
Ok so it may be that the little wire coming off the loom to the positive side of the coil remains there with the new setup (old one pictured), and then the red wire for the electronic ignition also to the positive side apparently. That was how I first had it setup but not with the extra one from the loom
It'll give me something else to try tomorrow :)
You have checked to see if you have a supply when ign on at pos side of coil? You could always replace the lumenition parts in the distributor for original points/ condenser and rotor arm.
Still nothing after putting the wiire to the pos side, but as you said if it's got resistor in the circuit it needs a separate supply, as it wont work with less than 12v
