preacherman Posted July 3, 2016 Report Posted July 3, 2016 Oil and filter due on the pinto engine. I am changing the oil spray bar as well. Are there any benefits in increasing the oil hole in the spray bar to get better oil flow Neil
Rallye Posted July 4, 2016 Report Posted July 4, 2016 no benefit, delivery volume is determined by oil quantity & pump pressure.
colr6 Posted July 4, 2016 Report Posted July 4, 2016 Spray bars were modded in the early days of the pinto which cured the problem of rapid cam failure so I would leave as is. Same old story frequent oil changes using good quality oil. Not using fancy fully synthetic stuff, these engine were not designed for it. A good quality multi-grade will suffice
