320 Posted January 7, 2018 Report Posted January 7, 2018 We're looking into options for roller garage doors for a new build garage, and security is the top priority! Anyone have a any recommendations for brands they've been impressed with, or ones to avoid?
Rich T Posted January 7, 2018 Report Posted January 7, 2018 No idea on garage doors but id be sticking retracting posts up between the door and the car.
Ray Posted January 7, 2018 Report Posted January 7, 2018 1 hour ago, Rich T said: No idea on garage doors but id be sticking retracting posts up between the door and the car. bloke next door to me found those totally useless, when he forgot they were there and they just ripped out as he hit them with the car, one even bent first
Ray Posted January 7, 2018 Report Posted January 7, 2018 my main roller shutter has 2 ground locks and 2 pin locks, then you cant operate the electric shutter without all 4 locks being in keeps, then the main workshop door is protected with an internal shutter door that locks, the exit door has a steel grill door that locks, and has the alarm panel attached, the main door has 2 locks, and outside that is another shutter door with pin locks, all windows also have pin locked shutters over them, fire exit totally blocked off both sides of the door and office again has an internal shutter door that's pin locked, the alarm has more passive detectors than you can shake a stick at, and 4 external sirens and 4 internal, the noise is piercing
eeb43 Posted January 7, 2018 Report Posted January 7, 2018 32 minutes ago, Ray said: my main roller shutter has 2 ground locks and 2 pin locks, then you cant operate the electric shutter without all 4 locks being in keeps, then the main workshop door is protected with an internal shutter door that locks, the exit door has a steel grill door that locks, and has the alarm panel attached, the main door has 2 locks, and outside that is another shutter door with pin locks, all windows also have pin locked shutters over them, fire exit totally blocked off both sides of the door and office again has an internal shutter door that's pin locked, the alarm has more passive detectors than you can shake a stick at, and 4 external sirens and 4 internal, the noise is piercing if that was round here someone would nick the doors!
Jerrytom161 Posted January 7, 2018 Report Posted January 7, 2018 33 minutes ago, eeb43 said: if that was round here someone would nick the doors! Would like to see them try .... better than fort knox !!!!! And then theres the 2 Dobermans wandering around inside , Ray forgot to mention that and they are both SAS trained with guns !!!!! ??⚔️⚔️??
eeb43 Posted January 7, 2018 Report Posted January 7, 2018 10 minutes ago, Jerrytom161 said: Would like to see them try .... better than fort knox !!!!! And then theres the 2 Dobermans wandering around inside , Ray forgot to mention that and they are both SAS trained with guns !!!!! ??⚔️⚔️?? you havnt been to wisbech have you????????? lol
Jerrytom161 Posted January 7, 2018 Report Posted January 7, 2018 yes not long ago , nothing compared to where Ray is ! ?
mattcortina Posted January 27, 2018 Report Posted January 27, 2018 once you have got a good secure shutter fitted, park a old car sideways across the front, or if you have the space they you can do it from inside, then they have to move a dead car before they can get through the doors.
Ray Posted January 28, 2018 Report Posted January 28, 2018 12 hours ago, mattcortina said: once you have got a good secure shutter fitted, park a old car sideways across the front, or if you have the space they you can do it from inside, then they have to move a dead car before they can get through the doors. i think that if you parked a car sideways across the front (outside) you would be advertising you had something worth stealing tbh
mattcortina Posted January 28, 2018 Report Posted January 28, 2018 good point there, if you are on an industrial estate or at home etc. im on a farm out of the way, so it just looks another old car parked up againsed another old farm building. if you try it outside a nice shiny lockup, it could stand out
