I should know but.... I have a english rear axle with 9" rear brakes the brake lines run into one cylinder and then across to the other, i'm sure i've seen axles with just a "t" section and then into each side which is alot tidier, can i just swop a pipe for a nipple or is that the atlas axle?? :?:?
sporty-corty16v,
If you wanted to run a T piece on the axle and seperate pipes into each slave cylinder then you can.You will need to fit another bleed nipple into the vacant hole in the right hand(near side) cylinder. :thumbsup:
sporty-corty16v,
What he said :thumbsup:
