1360 Crossflow Complete engine.  Not been used in a while but regularly turned over and dry stored. Was a very strong engine and kept up with much bigger things in my Lotus 7 Replica.
Spec:-
711M 1300 GT block bored +90 thou
Burton Pistons
Lightened and Balanced crank and rods
Lightened Flywheel
BDA Rod bolts
Burton HP Oil Pump
BCF3 Cam
Ported and Polished 1600 Sport head with the valve guides replaced and hardened valve seats fitted.
Lightened Rocker gear with spacers replacing the springs.
Fitted with a custom baffled, shallow big wing sump to suit Kit car applications.
£975 ono
Weber DGV Carb and manifold to suit above.
Choke removed as it is not necessary.
Custom throttle lever for smoother operation.
Manifold casting has all unnecessary brackets etc removed
Pipercross Panel filter fitted.
£100
711M 1100 Crossflow Engine for spares
Mostly complete a few bits removed for other engine builds.  Believed to be standard bore.  Was a very smooth runner.  Would make a good basis for a 1300 rebuild or rebuild as is.
£150
3.89 English Axle Differential.
Good condition. Nice quiet runner.  Only removed to fit a 3.54
£50
Type 1 Escort Gearbox.
Std 1100 / 1300 Ratios.  Not been used for a while but was working fine when removed.  Dry stored
£75
All items located in Herefordshire.  Collection preferred please.
  • 2 weeks later...
Posted (edited)
Many thanks for yesterday Stuart, good to meet you. The engine is now residing in my new shed awaiting time to paint it Modena Green instead of Plant Yellow!😂
Cheers, John.
Edited by accord83
