I have a Weber 28/36 carb on my escort, and when the weather starts to get cold (as it was this evening) the car starts to lose power and sometimes grounds to a hault after a few mins of driving... I'm guessing this is because the carb is freezing up. I have a k&n on it, and I think I could remedy the problem if I could choose the direction the air is getting sucked from, ie nearer the warm engine. I believe the 28/36 came off a cortina, does anyone know if there are standard type air filters available? I've tried one off a 32/36 and the holes are the wrong shape....!
Cheers!
Paul
Mate, I had exactly the same problem on my twin Venturi Weber on my old Orion, & I had a K&N just like you. Mine never started to freeze untill the weather was really cold, but annoying all the same. The first winter I had it fitted, it was fine, but last winter was a total nightmare.
Get a service kit for the carb, these are still available from Weber, as mine turned out to be a fuel and air leak from the carb itself.
That should sort it :wink:
its very possible its freezing.... have it sucking air off the exhaust manifold in winter... its not ideal and wont have as much power but it will stop it freezing
One of the causes for this could be the 'chill factor' of cold air hitting the carb at speed, causing the fuel/air mix to freeze and cause mayhem. With a standard filter the hot air directed from the exhaust prevents this.
I had this problem and made an ally shield for the carb, which sandwiched between carb and air filter, to stop cold air hitting the carb - it worked for me so may be worth a try :D
