Josh_gsy Posted June 17, 2007 Report Posted June 17, 2007 Can anyone tell me where i can look up info on the type of engines used in the various old skool fords and information about them? or is it just a case of lots of researching? Cheers!
Smudger105e Posted June 17, 2007 Report Posted June 17, 2007 Depends what info you mean, if you mean block casting numbers valve sizez etc then it's a lot of research, but if you just want to know engine sizes etc, that should be easily available...
Josh_gsy Posted June 17, 2007 Author Report Posted June 17, 2007 just looking for stuff like what type of engine they used in what cars pro's and con's of engines and what sort of upgrades were done on them?! am i just being lazy?
Admin Vista Posted June 18, 2007 Admin Report Posted June 18, 2007 just looking for stuff like what type of engine they used in what cars pro's and con's of engines and what sort of upgrades were done on them?! am i just being lazy? It's not that you're being lazy it's more that you're asking for an awful lot of info for one person to write down. The simple truth is that most Ford engines can be transplanted into any other Ford given the skill and sufficient budget, the ones most frequently found in Classic Fords are the X - flow and pinto, both can be easily uprated with good results. For big power upgrades the Cosworth motor makes plenty of appearances in turbo and N/A guises. Modern transplants frequently used include the Vauxhall XE and Ford zetec lumps. Popular V engine upgrades include uprated Essex engines, though less people elect to uprate the 2.8i cologne engine, instead preferring to go down the 2.9i Cosworth route.
Rick Posted June 18, 2007 Report Posted June 18, 2007 Can anyone tell me where i can look up info on the type of engines used in the various old skool fords and information about them? or is it just a case of lots of researching?Cheers! if you stay a member of this forum long enough mate youl learn all you need to know by reading through old threads and such
Josh_gsy Posted June 18, 2007 Author Report Posted June 18, 2007 i didnt know if there was a "www.history of the ford engine.co.uk" or any good books to buy? and i dont think i will be going anywhere to soon the forum is really good for learnng new info and tricks!
V8ian Posted June 18, 2007 Report Posted June 18, 2007 Most of the history of old fords is in peoples memories, , ask the question and you will get a multitude of answers on here. Ian
Wessie Posted June 18, 2007 Report Posted June 18, 2007 wikipedia is quite good just search ford engines
