Gagging to try the bosses new Mk1- :ykt:
Spare mex shell, used the wheels for Oldschoolgeezers 100E.
Posse using not 7"s for a change, (saved buying a rally rep) so to scale this mk2 tina gave its minilite rims.
However, tyre profile to high
Quick rumage through the the display cabinet, found this old 1/64 rod.
Front tyres perfect fit and brings profile down. Luckily found another Rod with the same tyre combination.
Quick mock up...
Temporary silver Gel Pen to mark up signage, will wipe off and paint later
Back with a bang Dazza ! You push it a bit further everytime much respect to you dude. Personelly been dabbling with bikes at the moment with some intresting results lol Just went and got a dremmel for my moddling :sad:
what kind of attachments came with the dremmel mate?
Polishing bobs, abrasive sanding bands, grinding stones, wire brush, bristle brush, cutting disk, drill bits. oh and flexi drive. Bate its made my hacksaw redundant already! Its saved me a fair bit of time, and hassle. :thumbsup:
I'll post a pic asap of the results ive had with it.
Part - 2
Heres a little lowering tip, vanguards cars usually have sprung axles, lift the spring shafts and remove the axle. Glue plastic strips (1mm thick - 1" scale) where the axle sits, then replace axle and spring clamps. No more than 2mm on the back or the leaf springs touch the floor (you could grind slightly).
Just because you cant see it, no reason to ignore detail....
Bumpers were a little to shiney, humbrol chrome dulls them a tad.
Dulled on the left
On goes the flag, used a homemade striping brush as per Kustom car Pinstripe crowd, the end bristled are cut at an angle which gives grat detail and control
Wish I hadnt given Posse the model van so early, would have looked tugging this....
NEXT..........
Interior (Bucket, scratch built cage)
Signwriting, Lights & Number plates
Chrome window and light surrounds
  • 2 weeks later...
signwriting redone -
Some other things ive been doing.
Was going to Hot Rod and trailer arch this, but may wait to see how Morley's Busa turns out....
Bought this one for Posse's Models wheels, found these touring car ones & may do "Puddy's" motor.
Had this one in progress for about 6 years, kind of Pro-Rat going on.
Cant decide what to do next.....
Next - Bolt Posse's Mk1 together.
  • 2 weeks later...
  • 2 weeks later...
Bought this tubing for the cage, great under heat very plyable.
Signwriting
The plaque was a tosh up, will change it.....
