Guest Airbag
I am in the middle of spraying my winter ride in Satin Black. i'm doing it just to tart it up abit for the winter.
I have sprayed the front end and it looks quite good. The problem i have is from some angles when the light hits it I can see faint streaks on the bonnet and wings. Is this overspray? and if so how can I get rid of it?
paint stripper should do the trick. :ykt:
Speak to Kirk on here, hes the paint god at the moment i think.
Jon
To get rid of over spray lines and keep the satin sheen let the paint dry out and harden up.then wet flat it with a 1500 or 2000 grade wet n dry ,this should give you a uniform and nice satin finish.This is how i finished a bike i sprayed satin black last year that came out sweet.hope this helps :thumbsup:
Guest Airbag
I would respray the whole car in one go...because what thinners you use and how much thinners you put in when you mix the paint will make a difference to how satin the paint is when you spray it. Therefore when you paint the back it won't match the front anyway!
It sounds like you are not over lapping the paint enough when you spray it, or are you using rattle cans?
im using cellulose paint mixed 50/50 with anti-bloom thinners.
adjust your gun to a wider fan. its less liely to leave streaks that way/
its a hard thing to get right unless you have the right light to work in, no trouble to go over it again though
Guest Airbag
Iʲll have another go this weekend and see how i get on with adjustinɡ the gun and crisscrossing. Thanks chaps
Guest Airbag
have adjusted the gun and given it another go and its come up great. Thanks guys
