Hi everyone, ive not yet put a speed sensor on the car as part of the 24v conversion. Cant find one to fit.
Would it make much difference if i didnt fit one ?
if you dont fit one the engine will try to stall when you pull up at junctions.
there is a red & black wire in the loom that you need to connect to the brakelight switch, this then becomes live when the brakes are applied and helps to sort the above problem out .i think you need to adjust the injection slightly. if not fit a speed sensor.
