PaulAshman Posted February 4, 2008 Report Posted February 4, 2008 Got a round grill for my mk2 on the way. Apart from obviously the lights what else do I need to do the square to round light conversion?
shaun1.6ghia Posted February 4, 2008 Report Posted February 4, 2008 looking forward to seeing that.. dunno what you'll need.. mine came with round lights. grill lights, maybe move some of the screw fittings (not all of mine line up) good luck.
hotrodholty Posted February 4, 2008 Report Posted February 4, 2008 isnt the front panel different like the mk1
shaun1.6ghia Posted February 4, 2008 Report Posted February 4, 2008 might be, not too sure... mine lines up fine.. my pannel does have round holes tho...
PaulAshman Posted February 4, 2008 Author Report Posted February 4, 2008 So are you saying i may need to change the front panel!!!
hotrodholty Posted February 4, 2008 Report Posted February 4, 2008 So are you saying i may need to change the front panel!!! you do on a mk1, however im not that clued up on the mk2
bomber1 Posted February 4, 2008 Report Posted February 4, 2008 So are you saying i may need to change the front panel!!! i think u need the proper round head light backing bowls not a new front panel i do have sitting in my lock up some nearly new halgon conversion lamps if u want a trade tho they come with mk1 backing bowls
escamino Posted February 4, 2008 Report Posted February 4, 2008 So are you saying i may need to change the front panel!!! i think u need the proper round head light backing bowls not a new front panel Yep, all Mk2 front panels are the same.
