Toby Posted February 15, 2008 Report Posted February 15, 2008 I think you new really what you wanted to tap in but you couldnt bring yourself to tap 2.2 No I just can't do maths
Toby Posted February 15, 2008 Report Posted February 15, 2008 So 2.2 secs from 11.5 secs is . GO ON THE PINTOS !!!!!!!!! Gaz - you know better than that - if Terry's 500 hp escort runs 10.0 then a 230 hp pinto with 75 extra hp wont drop 2.2 seconds from 11.5 to um..er.. a bit less..
kevmk2 Posted February 15, 2008 Report Posted February 15, 2008 The problem with a hightly tuned pinto is if you are running silly comp ratio then you run the risk of blowing it up easily with the gas i think. If your running 13:1 or more say, thats why on turbo'd car everyone goes low comp then chuck some gas in and take a bit of ignition out
Guest MK1gaz Posted February 15, 2008 Report Posted February 15, 2008 Jayson and Andy would easy run a low 10 with gas . Don't forget their power delivery is far superior to the turbos so they will make better use of it instead of wheelspinning
dommo1 Posted February 15, 2008 Report Posted February 15, 2008 Jayson and Andy would easy run a low 10 with gas . Don't forget their power delivery is far superior to the turbos so they will make better use of it instead of wheelspinning If you go by the 1.2 theory i think it could be well acheivable
Rick Posted February 16, 2008 Report Posted February 16, 2008 id add it just for the looks... when you see it come of out kj's bonnet its like a bull before it charges
Toby Posted February 16, 2008 Report Posted February 16, 2008 id add it just for the looks... when you see it come of out kj's bonnet its like a bull before it charges I like your comparison
