DEP Posted April 13, 2008 Report Posted April 13, 2008 What calipers are you using please? or what is the norm? One of mine has seized, and i m thinking now is the time to change them, so i can fit some 13ins wheels to the back
antz Posted April 13, 2008 Report Posted April 13, 2008 i know RICK uses rear discs. not sure what though. maybe check his project thread?
Tom Posted April 13, 2008 Report Posted April 13, 2008 i thought people used sierra calipers with fiesta discs mate
ratman Posted April 13, 2008 Report Posted April 13, 2008 I use cossy rear on mine and i run 13" rims on a escort axel I know mine is a cortina but its all the same
DEP Posted April 13, 2008 Author Report Posted April 13, 2008 i thought people used jelly mould calipers with fiesta discs mate Ok cool, thanks mate, mine has some other rear disc conversion on it, and i cant get a 13ins wheel over the caliper Thanks Steve, dont suppose you ve get any close up pics of them calipers and brackets?
Col-ashtonmobile Posted April 13, 2008 Report Posted April 13, 2008 i used granada calipers and peugeot 106 discs
DEP Posted April 13, 2008 Author Report Posted April 13, 2008 i used granada calipers and peugeot 106 discs Cheers Col, i ve just been looking at Burton s website, looks like i ve got one of their rear disc conversions, Im hoping to just replace the calipers and use the excisting mounting brackets. https://www.burtonpower.com/product_main.aspx?home.aspx
Toby Posted April 13, 2008 Report Posted April 13, 2008 Granny calipers and cossy calipers are the same, but everyone say's cossy cos they're performance!! I think the 106 discs are the same pattern part no. as the fiesta discs, I think they're off a van aswell but I can't remember which one.... I have bolt on brackets not weld on which is a really easy conversion. Hand brake cable was the only issue on mine (cortina - dash mounted) but I think the escort is easier. The cable is an early cosworth cable. A bracket is needed one side onto the car floor - I'm sure I've seen a kit including all the parts - with a bolt on cable bracket too.
DEP Posted April 13, 2008 Author Report Posted April 13, 2008 You typed quicker than me!! Try Burtons!!
Col-ashtonmobile Posted April 13, 2008 Report Posted April 13, 2008 make it your right toby i used the si,erra cable , i made the right hand bracket from a bedford midi van throttle cable bracket and the half shaft brackets ray i made ourselves , which we have made a job lot if anyone needs any , plus obviuosly machine the shafts to fit the discs
DEP Posted April 13, 2008 Author Report Posted April 13, 2008 Ok, just looked at Rally designs website, and these are the calipers that are fitted to mine. http://www.rallydesign.co.uk/product_in ... s_id=10563
Toby Posted April 13, 2008 Report Posted April 13, 2008 I see!! With a 14" wheel minimum!! Light though!
erick Posted April 13, 2008 Report Posted April 13, 2008 You need to modify the mounts and turn down the disc to bring the calliper closer to the axle. Don’t buy the kit from burtons it will not fit under the rs wheel
PIG Posted April 13, 2008 Report Posted April 13, 2008 i use cossie/granny calipers on the back without the cables with machined down fiesta 1100 brakes discs ian.im using fostek caliper mounts on mine as well
DEP Posted April 13, 2008 Author Report Posted April 13, 2008 I see!! With a 14" wheel minimum!! Light though! Exactly, i want to be able to fit 13ins wheels so i can use my slicks You need have to modify the mounts and turn down the disc to bring the calliper closer to the axle. Don’t buy the kit from burtons it will not fit under the rs wheel Ok thanks mate, as i said i m hoping just to trplace the R/D calipers with ones that will bolt on the excisting brackets and fit within a 13ins wheel
ratman Posted April 14, 2008 Report Posted April 14, 2008 Got my brackets from Yukspeed http://www.yukspeed.com/index.html will try and take better pic later
