Dependin on budget I'd go for either:
Princess four pots but I think u need to get the discs turned down to fit.
Cant remember for the life of me which ones :oops:
Or go for a set of Hi Spec calipers 8)
As u can tell these are the more expensive ones :wink:
Princess 4 pots will fit under 13" RS 4 spokes and Rally design do a 257mm disc that fits them perfectly without the overhang traditionally caused by using them with 2.8i vented discs. But you will need a spacer kit to use them with vented discs.
Thats the badger!! :D:thumbsup:
