xpackken Posted July 2, 2008 Report Posted July 2, 2008 Hi guys am i abit of i dlema . the avon slick racing tyres on my capper seem to be american sizes so they read 8.0/21.5/15 can anyone convert this into english size for me . ie eg 225/50/15 _________________ Honda CB400F
Admin Vista Posted July 2, 2008 Admin Report Posted July 2, 2008 Those aren't Metric sizes they're all in inches, unlike our own tyre sizes which are a combination of the two 225/50/15 225: - This is the width in mm of the tyre from sidewall to sidewall when it's unstressed and you're looking at it head on (or top-down). This is known as the section width. 50: - This is the ratio of the height of the tyre sidewall, (section height), expressed as a percentage of the width. It is known as the aspect ratio. In this case, 50% of 225mm is 112.5mm - the section height. 15:- This is the diameter in inches of the rim of the wheel that the tyre has been designed to fit on. Unfortunately I can't give you the same breakdown for the size you've quoted other than I assume 15 is a 15" rim, 8 is 203.2mm which may be the width and the 21.5 relates somehow to the section height?
razersedge Posted July 3, 2008 Report Posted July 3, 2008 i looked at slick tyres before and the only way i could see it worked was the 8 is the tyre width 8" 21.5 is the over all hight of the tyre 15 is the wheel size but i don't know if this is completely right
