mk2estate Posted September 7, 2008 Report Posted September 7, 2008 wasn't sure where to put this thread but i need some help please my brake servo/master cylinder is leaking from the front & i'm not sure what to do about it. it's already stripped some paint off from inside my engine bay so i needs fixing asap
escort new boy Posted September 7, 2008 Report Posted September 7, 2008 master cylinder is leaking not the servo
countrybumpkin Posted September 7, 2008 Report Posted September 7, 2008 yeah master cylander leaking, get it off quick before the oil goes into the servo
mk2estate Posted September 7, 2008 Author Report Posted September 7, 2008 yeah master cylander leaking, get it off quick before the oil goes into the servo do i have to drain the system to take the master cylinder off? & how do i fix the leak once it's off? sorry for all the newbie questions but i'm a newbie you see
countrybumpkin Posted September 7, 2008 Report Posted September 7, 2008 yes you will have to bleed the hole system you can rebuild the cylinder or fit new one i'll have a look though my records later and see if i can find the phone number for the company that supplyed my rebuild kit
mk2estate Posted September 7, 2008 Author Report Posted September 7, 2008 cheers for the quick responses people, i'll have to buy a brake bleeding kit then, i've never done it before is it just a matter of replacing seals and filling the system back up then?
mk2estate Posted September 7, 2008 Author Report Posted September 7, 2008 would this be the right kit to rebuild my master cylinder? http://cgi.ebay.co.uk/Ford-Escort-Brake ... m153.l1262 or does anyone know anywhere better to buy it?
mk2estate Posted September 7, 2008 Author Report Posted September 7, 2008 been looking this job up on t'net & haynes manual, looks like i don't have to bleed the entire system? just attach a bleeding kit to a bleed screw & pump the brake pedal till the reservior and cylinder are empty. take the master cylinder off, replace the seals, master cylinder back on, fill reservior up with brake fluid, bleed it through the system till there's no air bubbles & bob's yer aunties live in lover! please tell me that's the way to do it cos it sounds like not too bad a job as long as i don't spill any brake fluid (how much will i need btw?) p.s. sorry for being such a newbie
cjay2004 Posted September 7, 2008 Report Posted September 7, 2008 thisplace here does kits > http://www.brakeparts.co.uk only £7.43 as well the best way to do em i think is to buy 1 of them cheep bleeding kits(like a tune with a bearing in the end) and get some one just to watch it as u pump the pedal for air. as for the amount of fluid required hmmm from an empty system id say 1ltr + 1ltr for bleeding perposess
andytechno Posted September 7, 2008 Report Posted September 7, 2008 i had this problem but it was leaking on the other side ov the servo.ive seen the rebiuild kiyts but cant understand how to open the cylinder,it looks like a sealed unit.so i bought i new one and i had to sell my left bollock to afford it.
flyingbanana Posted September 7, 2008 Report Posted September 7, 2008 i had this exact problem last week.....and it had eaten my paint on the chassis rail and inner wing before i saw it i had replaced the seal few years ago but wasnt going to pay another £25 for seals....so i replaced the master with a new one i had kicking around for a few years.....had to mod it slightly to get it to fit....but no problems since good luck sorting it EDIT this is where i got my seals from www.pastparts.co.uk
mk2estate Posted September 7, 2008 Author Report Posted September 7, 2008 thisplace here does kits > http://www.brakeparts.co.uk only £7.43 as well the best way to do em i think is to buy 1 of them cheep bleeding kits(like a tune with a bearing in the end) and get some one just to watch it as u pump the pedal for air. as for the amount of fluid required hmmm from an empty system id say 1ltr + 1ltr for bleeding perposess cheers for that mate can't find them on their website but is the kit on ebay the thing i'm looking for? http://cgi.ebay.co.uk/Ford-Escort-Brake ... m153.l1262 edit: just noticed that it's for ATE & mines girling
mk2estate Posted September 7, 2008 Author Report Posted September 7, 2008 i had this exact problem last week.....and it had eaten my paint on the chassis rail and inner wing before i saw it i had replaced the seal few years ago but wasnt going to pay another £25 for seals....so i replaced the master with a new one i had kicking around for a few years.....had to mod it slightly to get it to fit....but no problems since good luck sorting it EDIT this is where i got my seals from www.pastparts.co.uk yeah, the paint's dissapeared from the chassis rail on mine too i'm gonna have a go at re-furbing it myself first but pastparts is a very useful place to know, thanks
cjay2004 Posted September 7, 2008 Report Posted September 7, 2008 yeah the web site is a bit of a pain, if u got asfar as the brake masters u gotta click on the type u have then theres an ACCOCIATED button , click that and ur see em? or alternitively give em a ring.... Rochdale 01706 666999 Bolton 01204 385888 think the one u want is part no:BMS1272 bore size 19mm? u might need to check that as they do 2 , 19mm and 20.5mm i think?
mk2estate Posted September 8, 2008 Author Report Posted September 8, 2008 there's a few different ones, i'm not sure which size mine is? is the number on the side of the master cylinder important? it's 74666220 if it helps! i think i might have to take it off first and make sure by taking it to a friendly local garage, he might be able to get the parts for me or even a new master cylinder. still need to get a bleeding kit though
mk2estate Posted September 8, 2008 Author Report Posted September 8, 2008 they sell repair kits here but how do i know which one i need from all the different bore sizes? http://www.merlinmotorsport.co.uk/BRAKE ... Qgod7z4Biw sorry if i'm being a pain in the ass
escort21 Posted September 8, 2008 Report Posted September 8, 2008 Master cylinder should have the size cast onto the side of it, to get the seals out you need to remove the master cylinder and remove the internal circlip and the insides will come out with a tap
mk2estate Posted September 8, 2008 Author Report Posted September 8, 2008 new master cylinder ordered, going to a mates garage to replace it tomorrow. more room to work there thanks for all the advice folks, very helpfull
