ok.....
looks like I have to move the v6 back a few inches to get it in the engine bay! (well not it but will only have 1" to get a rad in!) so obviously will have to cut and weld up the propshaft.
what way should it be done? do i cut the axle end or gearbox end? and how do i get round balancing problems?
please help this is one challenge (I'm told theyre challenges not problems!) after another!
wouldnt advise a DIY job unless you got the equipment to balance it. might just shake your car to bits else
I have done it, but TBH its probably better to get a pro to do it, as it is easy to get it out of Phase or badly ballanced
105speed may be able to do it for you :thumbsup:
or they will do u a custom prop :thumbsup:
Def speak to 105speed, they're very good service and cheaper than almost everyone else, plus they're proper osf! :ykt:
