Rick Posted February 22, 2009 Report Posted February 22, 2009 normal gear oil or something special. mines a noisy fecker at speed
ban1216 Posted February 22, 2009 Report Posted February 22, 2009 Should be a specific oil for lsd I know that comma do a specific oil for them
meXEco Posted February 22, 2009 Report Posted February 22, 2009 Castrol B373. http://www.castrol.com/castrol/sectiong ... Id=7027100
RETRO_AL Posted February 22, 2009 Report Posted February 22, 2009 Castrol B373. http://www.castrol.com/castrol/sectiong ... Id=7027100 Thats the stuff! used in my mex
meXEco Posted February 22, 2009 Report Posted February 22, 2009 Comma, 2 quid a litre Not worth bein a tight ass when it comes to oils.... Spend hundreds on the axle then put 50p's worth of oil in it.
X-pack-Glyn Posted February 22, 2009 Report Posted February 22, 2009 Comma, 2 quid a litre Not worth bein a tight ass when it comes to oils.... Spend hundreds on the axle then put 50p's worth of oil in it. used it for 13 years, never had a noisy plate yet! Comma is not the cheap shit many think it is, would you like the spec sheet?
ban1216 Posted February 23, 2009 Report Posted February 23, 2009 I use the comma diff oil and have never had aproblem
Rick Posted February 23, 2009 Author Report Posted February 23, 2009 are lsds noisy without the right oil, i just hope i havent damaged it.
bigdaz27 Posted February 23, 2009 Report Posted February 23, 2009 if its noisy at speed then i would say it was fooked
Rick Posted February 23, 2009 Author Report Posted February 23, 2009 if its noisy at speed then i would say it was fooked its hard to tell really its only noisy when being driven if i coast its no longer noisy but surely the diff is still turning ? its hard to diagnose til i can get it over a pit on some rollers but the noise is deffo coming from that end.
danny69 Posted February 23, 2009 Report Posted February 23, 2009 It is still turning but not under load. If it goes quiet it points to the Crown and pinion wheel. If it stayed noisy it would more likely be bearings.
ban1216 Posted February 23, 2009 Report Posted February 23, 2009 I think that plate type lsda are a bit noisier than standard diffs though
LEONMEX Posted February 23, 2009 Report Posted February 23, 2009 plate type in mine with b373 castrol never hear a clonk or rattle from it
Rick Posted February 23, 2009 Author Report Posted February 23, 2009 its more a whining noise like a turbine spinning up
mk1mexico Posted February 23, 2009 Report Posted February 23, 2009 Sure its not a wheel bearing Rick??
Rick Posted February 23, 2009 Author Report Posted February 23, 2009 not 100% but 99% sure. i replaced them last year and theyd still whine with the clutch dipped
