the way i done mine was two long screw bolts through the front poss through front number plate the one little screw on the wheel arch each side. no cutting should be needed :thumbsup:
Secure the 'front' using your number plate screws, then secure the sides by screwing the ends to the return lip of the wheel arch. That will hold it perfectly adequately, and without a row of screws along the top :thumbsup:
ive always used it in the past to fit body kits for people had none crack or split yet
briliant stuff
THIS IS PROBABLY THE BEST ADHESIVE SEALANT ON THE MARKET AND IS NON SHRINKING AND PERMENANTLY FLEXIBLE.
IT HAS MANY USES INCLUDING BONDING BODYKITS ,SPOILERS , LAMPS ETC.ALL TOU NEED TO DO IS TO MAKE SURE THAT BOTH SURFACES ARE CLEAN AND FREE FROM WAX AND DUST.
http://cgi.ebay.co.uk/TIGER-SEAL-ADHESI ... 240%3A1318
