BaileyMex Posted May 25, 2009 Report Posted May 25, 2009 MK1 6 clock dash Removing the speedo cable from the back.... Is there a knack to it coz mine wont bloody budge
LEONMEX Posted May 25, 2009 Report Posted May 25, 2009 there is a nack but not sure what it is i think you have to open up the outer case slightly but normally a good twist & pull does it for me
BaileyMex Posted May 25, 2009 Author Report Posted May 25, 2009 i've tried twisting the knurled nut and giving the frustrated yank but still no budge
flyingbanana Posted May 25, 2009 Report Posted May 25, 2009 i put a small screwdriver inside it and raise the lug slightly inside while pulling it at the same time
BaileyMex Posted May 25, 2009 Author Report Posted May 25, 2009 I'll have another go in the week, hardly any room to get a screwdriver up behind the dash tho
flyingbanana Posted May 25, 2009 Report Posted May 25, 2009 helps if you pull the clocks forward has well from the dash
wild pete Posted May 25, 2009 Report Posted May 25, 2009 theres a plastic tag u need to squeeze it in and pull ,it shouldnt be tight if you get it rite
