Not sure where to post this really,
Got a nice glycerin filled fuel pressure gauge to fit,
Is it ok to fit it in-line in between the twin carbs themselves or will that not give an accurate reading as the fuel has already passed the first carb :huh:
when i fitted my pressure reg i was told fit it as close to the carbs as poss but before the actual carbs,so my guess is in between them would'nt be as accurate as it should be.
Just before the carbs.
If you'r running a Filterking in the enginebay you can mount it on it ( just remove the brass plug).
already got a filter king mounted on the inner wing
had a look for a removable lug and all I can see is this, but not sure if it comes out :huh:
if you read the destructions it tells you to fit gauge set pressure then remove the gauge. fit the new one just after the filter king outlet :thumbsup: 2.1/2- 3lb
sorry to hijack your thread BaileyMex but ive recently bought a filter king but lost the instructions!!!which one is the outlet and inlet pipe?? left or right??
Ta` very much
Greg
Ta` very much
Greg
The one pointing to the bottom is inlet pipe
:thumbsup:
Hi Wayne,
No instructions with the guage and the filter king has been on the car for years, I wanted to fit it and leave it there, that's why I went for a glycerin filled one
