steve dray Posted June 1, 2010 Report Posted June 1, 2010 Has any one had any experience with fibre glass door skins??? I see you can get them for anglias. Just wondering how you would go about fitting them to a steel door frame? I imagine they would have to be bonded on, but I wonder how long it would be before they start to crack, or er, fall off!!
Pipster007 Posted June 1, 2010 Report Posted June 1, 2010 Double sided sticky tape should do the job Sorry, not really helping am I Off the top of my head, I'd say Gary at Retro would be one of the best peeps to ask
steve dray Posted June 1, 2010 Author Report Posted June 1, 2010 Double sided sticky tape should do the job Sorry, not really helping am I : (runs off to B & Q to buy tape !! )
baz105e Posted June 1, 2010 Report Posted June 1, 2010 tiger seal should do the trick, why not go for full fiberglass doors from team deville steve, you know it makes sense
stuartp Posted June 1, 2010 Report Posted June 1, 2010 i have often wondered if fibreglass doors are road legal and even if they are, would they not afford you pretty much zero protection in an accident?
Stu_B Posted June 1, 2010 Report Posted June 1, 2010 Yeah you'd want a full cage with door bars There is definately some weight to be saved in Anglia doors though, they weigh a ton!
stuartp Posted June 1, 2010 Report Posted June 1, 2010 Yeah you'd want a full cage with door bars There is definately some weight to be saved in Anglia doors though, they weigh a ton! so would they be legal to have on a road car? i'm tempted to get at least one for my escort as the drivers door doesn't fit all that well i'd want a cage with the door bars for sure!
Andrade Posted June 1, 2010 Report Posted June 1, 2010 Yeah you'd want a full cage with door bars There is definately some weight to be saved in Anglia doors though, they weigh a ton! tell me about it then you wonder why anglia doors dotn shut that well
GT_lenny Posted June 1, 2010 Report Posted June 1, 2010 reliants have fibreglass doors? and theyre road legal?
steve dray Posted June 1, 2010 Author Report Posted June 1, 2010 Did have a set of fibre glass doors but decided against it, as has been said they don't close that well at the best of times and I could imagine them cracking quite quickly. Then I saw the fibre glass skins available from Team Deville and thats got me thinkin!! The steel frame would give it some strenth with some sort of door bar welded to the frame, then the fibre glass skin plus some trimming of the frame will reduce the weight of the doors plus get rid of the tin worm in mine . As said though I am wondering what the best way would be to bond them to the frame without them falling off!!
Fiesta Steve Posted June 1, 2010 Report Posted June 1, 2010 I think any good sealent adhesive all the way round would be more than enough for them to stay on.
w p e Posted June 1, 2010 Report Posted June 1, 2010 why not drill 1/8th holes counter sink the holes then rivet the skin on or use sikey flex. or just fit glass doos like i have and they fit better then the real thing
tina2 Posted June 1, 2010 Report Posted June 1, 2010 Mate of mine was considering f/glass doorskins for his Sunbeam . Local MOT tester could see no problem with legality.
