bomber1 Posted January 12, 2007 Report Posted January 12, 2007 right here goes. on my escort ive just changed the clocks from a lhd set up to a rhd bda set. the problems ive got are know this. the rev counter is reading low and the temp guage is over half way most off the time tho the engine doesnt seem to be running hot from other veiw points. would the guages be diffrent because off the diffrence in engines. ie bda clocks to pinto engine just to add the new bda clocks come from a reliable source and working when removed
escort21 Posted January 12, 2007 Report Posted January 12, 2007 The temp gauge would read depending on what sender the pinto screwed into the block...maybe try changing it
bomber1 Posted January 12, 2007 Author Report Posted January 12, 2007 how would i know i was getting a diffrent sender sorry to sound thick just realy doing my head in know
Alan G Posted January 12, 2007 Report Posted January 12, 2007 Test the gauge first... Touch it off an earth and it should noticeably go straight to the right (HOT)!!
bomber1 Posted January 12, 2007 Author Report Posted January 12, 2007 Test the gauge first...Touch it off an earth and it should noticeably go straight to the right (HOT)!! whats that the wire that goes to the sender
Admin Vista Posted January 12, 2007 Admin Report Posted January 12, 2007 The sender essential changes the resistance between the gauge and earth to give you your reading according to temperature, i.e. the hotter the engine gets the lower the restance to earth and the higher the reading on the gauge. If you earth the wire to the sender it should go to Full scale deflection as it simulates a resistance of 0 But I'm not sure how that proves that you have the wrong sender for your gauge, it does prove your circuit back to the gauge is good though.
bomber1 Posted January 12, 2007 Author Report Posted January 12, 2007 cheers vista ive been back out to the car and started it from cold and sat there watching the guages. just to make sure the temp guage wasnt acting as the fuel guage or vice versa i took the sender wire off and the gauge stayed still then earthed it out and it went off the clock. ive just come to the conclusion that the guage starts and stops at diffrent possitions. as on the last guage it ran at a third on the temp guage and this one two thirds accross the guage
Admin Vista Posted January 12, 2007 Admin Report Posted January 12, 2007 If you took the wire off, then the gauge should have dropped back to the bottom of the scale.
Admin Vista Posted January 12, 2007 Admin Report Posted January 12, 2007 Get it hot and disconnect it, it should drop back to minimum immediately
bomber1 Posted January 12, 2007 Author Report Posted January 12, 2007 will that straighten the guage out
Admin Vista Posted January 12, 2007 Admin Report Posted January 12, 2007 No, but it will tell you if it's responding correctly. I think the problem is the sender rather than the gauge. It may need one that has a higher resistance when cold, so as it heats up your gauge reads lower down the scale.
bomber1 Posted January 12, 2007 Author Report Posted January 12, 2007 ok will try that after work tomorrow. how do i go about finding a higher resistance sender sorry to be a pain
Admin Vista Posted January 12, 2007 Admin Report Posted January 12, 2007 That I can't answer, do you have access to the car it came out of and can use the sender it has (assuming it fits)?
