not sure what's going on but,i got some mirrors off an old taxi and they are the same bodies as the escort/capri type and electric.so would not be that difficult to wire up.did ford ever offer electric as an option on capris then?
not a great pic but you can see the wires.
if it was from the factory it would have twin leccy mirrors not one leccy and one manual, then again it could have been done the mobility sceme for a disabled driver as a dealer upgrade, i cant see the factory fitting half a wiring loom but i can a dealers :?
the loom even in the cabs are ford looms so are the mirrors, they are German offerings :thumbsup:
Yepp its factory and it was only one side (passenger side) on the Capri mk3. Mainly 2.8 injectors had it some others had it as an option.
Have an '80 2.0 S here imported from Spain where the only option to choose from was the collour ( headlight wash, vented rear windows, full tinted glass, one leccy mirror & sun roof was standard there).
So yess, factory fitted one manual & one leccy. Joystick for the leccy one is fitted central dash low down. Intructions are in the Capri owners manual.
Ford never fitted capris in the UK with electric mirrors, the only capri that came with electric mirrors was the tickford capri and they were not the same as the pictured ones, the pictured ones have come from a fx4 london taxi, they do have the ford logo on them, it's a simple conversion to fit and you can see clearly out of the passenger mirror unlike when people use the drivers side mirror from a lhd capri, the angle is all wrong to see from the right hand seat.
mike
Thats the one! joystick in the center, its also got a fader control a bit like the xr3i's used to have! its a 1988 2.0 Laser
