I done an oil and filter change about 5 weeks ago and checked oil other day and it was just over the minimum line so she must be burning it off? I was at work and my father in law got me some oil from halfords as he was near there, But I'm not sure if I can use part synthetic?
I have read not to use it and also read you can and in halfords in their flip chart it say you can use it??
I'm a bit confused and not sure if I should top her up with it?? Oh yeah its a 2.8 Capri!
Cheers
What oil is it? If it's a modern thin oil then there's every chance it's being burnt off. I stick to the originally recommended 20/50 for old fords
Cheers for the quick reply!
When I changed oil I used halfords 10w40 think that was a semi-synthetic? The oil my father in law bought was halfords 10w40 part synthetic - for car built after 1990, mines an '83
Seem to remember seeing a 20/50 "classic" oil in Halfords, used to use Duckhams years ago,not sure if it's still around though, I use Mobile semi synthetic in the Cossie.....
I'm going into town in the morning so I might as well change it in halfords just in case? I will look out for the 20w50 classic. I may go for something thats not synthetic which I guess that was all there was around back in the swinging 80's!
Right... I have changed oil in halfords today they and found a halfords classic oil which is just mineral at 20w50 so do you think this is safe to use??
Heres a pic any way!
Don't top it up, drain out what you have in there and replace it. Don't mix mineral and synthetic oil
Bugger... I have already done it! About a litre? What would happen mixing the two?
they wont mix,same effect as mixing oil and water,they just stay seperate,best to drain it and the change the oil totally
Ahh right! I see, I will do that soon as..
Valvoline 20/50 when I can, but I have used that Halfords stuff in the past, mine is due a service before the summer and it will get the Valvoline stuff :thumbsup:
