popeye Posted February 23, 2015 Report Posted February 23, 2015 Hydraulic Hand Brake.. Any one using one of these... what make... Vertical or Horizontal your views please..
sutton4ord Posted February 23, 2015 Report Posted February 23, 2015 I was thinking about something like this for the tina
Danish Posted February 23, 2015 Report Posted February 23, 2015 My MOT man said this is the one thing he would have "an issue" with, all the other rally mods he's happy with. It does look good though
theloudboy Posted February 23, 2015 Report Posted February 23, 2015 If you only have a hydraulic handbrake u won't get an MOT unless your very good friends with the tester
mk2 mike Posted February 24, 2015 Report Posted February 24, 2015 As above. The MOT States the handbrake MUST be mechanical. Unless your MOT tester doesn't notice...[emoji6] That one in the pic looks trick though!
popeye Posted February 24, 2015 Author Report Posted February 24, 2015 must be a way to convert them !!
eeb43 Posted February 24, 2015 Report Posted February 24, 2015 must be a way to convert them !! stand on his foot when he is looking at the handbrake
gearbox100 Posted February 25, 2015 Report Posted February 25, 2015 most leave the standard handbrake in situ and then plumb one like above in at an angle to the side, got both then , cant fail mot.
piekey Posted February 28, 2015 Report Posted February 28, 2015 I thought it said pre 67 cars can fit ? May have been an old bulletin i read. Means all 105e 100e stuff is a go'er.
jamie956 Posted February 28, 2015 Report Posted February 28, 2015 As said you need a mechanically operated hand brake for MOT, when I did mine I just fitted two TBH the hyd is better placed up by the gear lever then just leave the mechanical in its original place, I was lucky as I fitted a new tunnel I moved the mechanical back between the seats out of the way you can just see the end of it in this photo. If you wanted to be trick you could use a electronic hand brake mechanism or a electronic hand brake calliper, not sure how complicated they would be to activate electrically but im sure something could be figured out.
