Danish Posted August 4, 2015 Report Posted August 4, 2015 I've converted my Atlas axle to disc brakes using a kit from Fostek. I'm undecided whether to plumb the callipers in using short flexi-hoses to the calliper, then hard lines along the axle tubes, or hard lines the whole way, or even custom flexi-hoses all the way. Any opinions?
katana Posted August 4, 2015 Report Posted August 4, 2015 As they don't move - I chose hardline all the way with braided flexi to the body bulkhead as I run internal lines 1
Danish Posted August 4, 2015 Author Report Posted August 4, 2015 Thanks for the quick reply. Did you use a T-connector, or run a hard-line between the two wheels?
katana Posted August 4, 2015 Report Posted August 4, 2015 Tee on diff case with hardlines each side. As the calipers only have single port, you'll end up with a tee somewhere. 1
Col-ashtonmobile Posted August 4, 2015 Report Posted August 4, 2015 I used flexy to the calipers as it made it easier to change the pads, no need to disconnect the hydraulics... 1
Admin Vista Posted August 4, 2015 Admin Report Posted August 4, 2015 I used flexy to the calipers as it made it easier to change the pads, no need to disconnect the hydraulics... Same, flexi to the caliper and then again between the axle and shell. 1
khanlad Posted August 4, 2015 Report Posted August 4, 2015 Yeah same for me, flex body to axle, hard, then flex to calipers 1
