I am struggling to find a standard 5 speed xflow clutch kit. Im sure before I just got a early 1600 sierra one. But trying local factors no joy. Does any one have a part no.? Or know where I can get a complete kit from? Many thanks
I you're looking for something off the shelf that says "x-flow 5 speed gearbox clutch kit", then that's where you're going wrong. There was no RWD standard 5 speed x-flow installation from the factory, you just need to know which 4 speed one to use that will fit.
Can anyone help?
As long as the cover fits the flywheel and has 1" 23 spline plate should be no problem. If Sierra kit is good on both counts then use it.
  • Like 2
Thanks for the replies guys. Vince have you personaly used one of those clutches? Only because i used that borg and beck number which cross-referenced to an luk number that was the wrong one. But if some knows the beck one is good il go for that
