Hi all
Lookin at fitting twin carbs on my mk1 however it's rod controlled on the existing carb, the twin carbs are cable set up, what's the easiest way to convert the old to new set up? Any thoughts?
Thanks in advance
You will have to weld a rod on the cross shaft of the pedal approx 100mm long. Cable then would go through bulkhead and use poss mk1/2 escort throttle cable. Other alternative is poss swop cortina throttle pedal for an escort one if the shaft is long enough to go through pedal box and again use escort cable.
