Hi, does anyone have an Atlas rear axle for a MK3, 4, 5 Cortina they want shut of?
I want to replace my Koln axle with an Atlas.
Ideally in the South London Area (I'm at CR8).
Thanks
Richard
Did a bit of checking last night and the axle you want is either out of an estate or 2.3 v6. These are the ones that are h/ duty
Thanks Colr6. Very helpful. Other than checking half shaft splines/diameters do t suppose you know what external clues there are between a heavy and light duty Atlas?
the diff cover and the pinion nut on the atlas version is mostly protruding from the flange
On ‎20‎/‎10‎/‎2018 at 16:26, RWL81P said:
p100 ones are more heavy duty as well
I understand that the p100 uses a Borg Warner axle, so I would struggle to get the ratio (3.09) I am after, unless someone knows otherwise.
sierra shape p100 is an atlas cortina shape is no use for anything
It's a minefield this axle search. Can you explain what the issue is with the Atlas Sierra P100? Does it have the mounts on the Pig Head and can it accept a Capri diff?
This is what I understand so far then about the Cortina axle varieties:
·         Cortina Banjo = English (No good in terms of strength and ratio options that I need)
·         Koln (Looks like an Atlas but with unequal bolt pattern) = (No good in terms of strength, LSD option or ratio options that I need)
·         Cortina Atlas Light Duty (As fitted to V6/Estate) - Has longer and narrower half shafts with more splines (22 I think) = No LSD option
·         Cortina Based P100 = Borg Warner (won’t accept a Capri Diff)
·         Sierra Based P100 = Atlas (Don’t know anything else about it)
sierra p100 atlas is same style as capri atlas pigs head but 10mm thick tubes and fully floating shafts
you need a cortina atlas axle nothing different and the capri cw/p and lsd will go in it
